Michael A. Terrell
jakdedert said:The cutting oil is a good idea, essential even. That said, I don't
think you want to be grinding on a saw blade of any kind. Aside from
the difficulty in obtaining any kind of precision, the heat generated
will degrade the steel.
Has anybody used those hole cutters which are a pilot bit with a single
carbide 'knife' on the end of an adjustable arm? I've seen--but not
used--them.
http://www.cleavelandtoolstore.com/images/fc53_lg.jpg
A fly cutter? I have cut some very clean holes with them, chucked
into a 3/8" variable speed drill. the trick is to cut about half way
through, then finish from the other side. A drill press is easier, and
safer to use with this type of tool. I cut a lot of holes for panel
meters with one, about 30 years ago. is a
good place to ask, but beware, they don't pull any punches, and tell
people what they think.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
