The sort of gauge used in casings. Say something like a 3 inch diameter
hole, fairly neat, so something neater than chain-drilling then filing.
That can be very neat depending on your skills. The best way would be a
hole punch like a Q-Max - but one that size would be very expensive.
No fancy tools available eg no slow rev hand drill, fly-cutter on a mill
etc
I'd probably use a holesaw but these too can be expensive for decent
quality ones. Otherwise a nibbler. But that might just come under 'fancy
tools'? Although the hand ones aren't that expensive. Monodex is one make.
There are power ones - air operated, driven via an electric drill, or self
contained electric.
*Go the extra mile. It makes your boss look like an incompetent slacker *
Dave Plowman
[email protected] London SW
To e-mail, change noise into sound.
I was wondering about about those multi tooth ring cutters concentric to a
pilot drill, remove the unwanted ones, by turning backwards, to free.
Grinding
down most of the teeth leaving just those of one "set" say teeth 1...5...9
to reduce the bite that would stall a non-geared down drill, plus a
double-bunded
pond of cutting oil.
