A simple battery charger is not half wave, it contains a bridge rectifier which will show two half waves side by side, one from the positive half cycle and one from the negative half cycle.
The waveform will have a DC component and also a AC component. If charging a battery, current will pass in pulses when the charger volts exceed the battery volts.
If you are getting AC sine wave out, then the rectifier is shorted.
