Orcad PCB 386 V4.42 Doesn't work on windows 2000
Nuri Akman
Hi everyone,
I'm (trying) using Orcad PCB 386 V4.42 on windows 2000. But, it
doesn't work. I have a BATCH file for configuring Orcad's environment
variables. When I try to run that Batch, screen is getting black.
Also, I try to set environment variables within windows's environment
variables section. But result isn't change.
Does anyone can help me?
Note:
My system is Pentium III 933 Mhz, windows 2000, 128 Mb ram, 20 gb
fat32 HDD, 32 Mb TNT video card.
Boris Mohar
Hi everyone,
Note:
Try asking [email protected] I have seen it run on Win2000.
4.42 is the ESP version. What is the PCB386+ version? The latest is 2.22
before the shelved it. It is one of the bigger mistakes the made.
Regards,
Boris Mohar
Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
Aurora, Ontario
Mostafa Kassem
Nuri said:
Hi everyone,
Note:
What video driver are you using? Have you tried an ATI card?
Mostafa
Rein Wiehler
Nuri said:
Hi everyone,
Note:
he must be refering to Install V4.42. We have PCB386+ running on NT4
rw
Chuck Harris
There is a basic problem when you install Orcad PCB on any windows 95
and up system. The routines that Microsloth uses to return basic bits
of information about the environment, don't work correctly.
Orcad's generated install batch file ends up just full of constructs
like:
IF NOT %C:\ORCADESP\. == C:\ORCADESP\. Goto ENVERR
and
IF NOT . == FALSE. Goto ENVERR
As a result, your install program will fail miserably. You will have
to do everything by hand, or boot an old version 6 MSDOS, and do the
install from there.
-Chuck
