Operating Current Of Stepper Driver IC?
Hello,
-we are using the NJM2673 dual H-bridge stepper driver IC to power our stepper motor.
This IC has a 5V input to power its control circuitry.
NJM2673 DATASHEET:
http://www.2shared.com/document/_rlD5vgE/NJM2673_E1__STEPPER_DRIVER.html
At the top of page 5 of the NJM2673 datasheet, it says that the operating current is 60mA max.
However, i am not sure if this 60mA value refers to when the internal h-bridge transistors are being switched or not.
do you believe that when this IC starts switching the transistors of its h-bridges, that the operating current taken by its 5V input will likely be much more than 60mA?
...after all, the h-bridge transistors are BJTs, and there are 8 of them, and they are obviously going to need base current.
It matters not. This is the maximum current it will draw if the device is being used within its specified limits.
I would not.
