MRW
I'm working with these microphones because I have them already:
http://www.knowlesacoustics.com/knowlesacoustics-apps/microphone_productdetail.do?product_id=12
Assuming that the voltage output of the mic at 40dB re 20 uPa is 5
microvolts, would using two opamp stages for a pre-amplifier circuit
be suitable?
I think 5 microvolts is too low, so I'm trying to step up the voltage
to at least 50 mV. That would mean that I would need a gain of 10,000.
But looking thru some of the opamp datasheets, I'm noticing a gain
bandwidth of about 7Mhz for most of the opamps that I've seen so far.
This would mean that the usable bandwidth goes down to 700Hz.
So, I was thinking if I have one amp with a gain of about 400 followed
by another opamp with a gain of 25, then I should be able to step-up
my microphone output voltage to some workable level.
What should my concerns be with using this simple two opamp preamp?
be suitable?
