I have an opamp circuit with the two resistor configuration. I am using the OPA552 with rail voltages of -9V and 41V. The resistors are 30.1K and 10K. See picture. In TINA, I get clean amplification that follows (1 + R1/R2). On the PCB, I get the same amplification with noise. In the attached picture, I am seeing the output of a low frequency sawtooth wave. The "noise" you see in the scope picture is a clean "sine" wave of 1.2 MHz when I stretch it out(See picture). I look at the input (0-8V) and the rail voltages with the scope and they are all clean. I can change the input frequency to DC and the noise is still there. I changed the load resistance by adding 3K ohms in parallel and no change. The PCB is surface mount design and the resistors are close to the opamp. It looks like I need a capacitor across R1 and/or R2. Is that a correct fix or am I missing something ?
Platforms
Content
