Yannick said:
I was thinking of using the OPA695 current feedback amplifier for my
transimpedance amp. This amplifier is capable of delivering much more
gain over a much larger bandwidth... I also see the equi current noise
at the input is much larger then with the FET input opamps like the
OPA657 but if the signal is large enough (lets assume you have an
avalanche photodiode) isn't it better to use such a current feedback
amp in stead of a voltage feedback?
The reason why i am considering this is because i never will be able
to measure 300-500Mhz with the voltage feedback amps. I want higher
frequencies because this will give me far better distance resolution
with phase measurement due shorter wavelength.
Your resolution ultimatly depends on the resolution of your adc converter
asuming thats what ultimatly measures the phase, also any errors thermal
drift etc, and probably most importantly SNR, and how much filtering you do.
the signal strenght i get reflected back from the target various
enourmously, have you tried the signal strenght after relecting of a target
at your maximum range? i dont think its safe to assume your signal strenght
is large enough, this is the asumption i made at the start and found it to
be very wrong indeed. APDs are great for amplification, but you do get more
noise as you increase the amplification level (by increasing the bias
towards Vbr), upto a point where the noise sudenly increases tremendously.
Noise can be averaged out but it depdnds how long you are going to wait,
errors can be nuled out by calibration, as long as it doesnt drift too much
over the short term wich makes it a good idea to keep power disipation low
as posible.
If you use a much highr frequency, although you get more phase change per
distance you get a corespondingly lower SNR due to lower Zc so u dont
necesarily gain anything. of course using a large lense as possible for the
detector has a lot to offer indeed, as would be using a larger laser if this
was safe to do, but very expensive.
To get best noise performance of the input stage it wld be well to consider
an input amp that has a noise figure optimal for the impedance of the
detector+input capacitance. at higher frequencies this becomes quite low and
a bipolar input amp might be better, although input curent noise is higher,
input noise voltage becomes much more of an issue. input noise voltage
/input noise current = optimum input impedance for lowest noise.
But tbh i think i wld still strongly consider a discrete input stage such as
a DG mosfet or even low noise bipolar, as it potentialy has lower noise than
any op amp you are considering. At 500mhz a 10pf total capacitance has a zc
of under 50 ohms, so as someone already sugested even a 50ohm MMIC might be
wel worth considering, even with the opa695, it looks quite good on paper
with an optimum input impedance of 100ohms, especialy if you use this as
second stage of amplification.
A simple discrete first stage with no feedback or tuning would of course
have a frequency response with a simple slope but this could be corected by
a 2nd stage with response sloping the other way. this would be much simpler
and have less potential for many components introducing unforseen noise,
instability, emi pickup and maybe phase variance etc and give you more
choice of components and configurations to use. but its up to you to
evaluate all this in this aproach lol.
300-500mhz is quite high for the inexperienced, hard to see whats going on
as scope probes alter the circuit so considerably, and is pushing the limits
of many scopes anyway. If you already have it working at 20 mhz id see how
the rest of the circuit performs, then you can see what is the limiting
factor in your resolution.
At this high frequency it would be interesting to look into using multiple
striplines to provide a multiple tuned frequencies of the input stage, and
reduce the efects of the capacitance, posibly even a coax step up
transformer.
Colin =^.^=
