Thankyou, I was under the impression I could work out the gain = Vout/ Vin
If this were the usual op-amp circuit, with non-inverting gain for a single input applied to the (+) input, then you could say that the "gain" for that input is 1 + R
f / R
a. You should derive this equation yourself to prove you know what you are doing.
However, it becomes a little more complicated when the output voltage and the input voltages are all specified but the resistor values are not. Do what
@Harald Kapp said: calculate the voltage at V
p. This will be the same as the voltage at V
n. From this information you should be able to calculate resistor values for R, R
f and R
a to "make it so" to produce 5V output with the three specified input voltages. Note that the resistor values are arbitrary in their absolute values.
