Hi Adam,
at first, a general remark to my questions: By asking "why?" I could - in most cases - imagine what you mean (for example: fc) - however, I thought it would be necessary for the reader (newcomer) to know the definition. In general, I think no symbol or abbreviation should be used in any text without a corresponding definition.
Some comments from my side follow:
Answer from Adam:
I was under the impression that when you use negative feedback this reduces the gain uncertainty of the op-amp which in open loop can have quite a high tolerance between the same types of op-amps. Also I thought negative feedback reduced output impedance and increased input impedance. The reduction in output impedance will allow the op-amp to drive higher capacitive loads than when in open loop configuration and the increased input impedance limits the loading on the source driving it. So that’s why I used the word stabilise. Maybe I need to use a different term?
In short: We apply negative feedback to fix/stabilize a DC operating point (like in transistor amplifiers).
At the same time, this is connected with additinal advantages: Increase of input resistance (only non-inverter) , decrease of output resistance, closed-loop gain practically determined by external resistors only, closed-loop bandwidth increase.
However, in electronics each parameter improvement is connected with a degradation of another parameter - in our case: Degradation of dynamic stabilty (stability margin is inversely proportional to the feedback factor). This is demonstrated with the help of loop gain analyses (Nyquist stability criterion).
This is important because if this product ever equals -1 which is -1 <–180 ˚phase shift the circuit could oscillate.
LVW Said:
This is in contrast to Fig. 6a, 6b, Fig. 7 and 9 (phase margin against 0 deg). This results from the confusion regarding the definition of loop gain (with/without sign inversion) .
Answer from Adam:
Sorry I don’t quite understand this point can you please clarify what you mean. Can you suggest better wording or should it be removed.
In your text, the stability limit is for a loop gain of "-1" (phase: -180deg). However, in the drawings the stability limit is at -360deg (0 deg).
All loop gain simulations include, of course, the sign inversion at the neg. opamp input. This is correct because at low frequencies (including dc) we always require negative feedback. Consequently, the loop gain must be defined as LG(s)=- Aol(s)*beta .
That means: Acl=Aol/(1-LG) and we have instability for LG=+1 (phase: -360 or 0 deg).
With other words: We have to distinguish between (a) the pure product Aol*beta and (b) LG=- Aol(s)*beta. Thus, the contradiction is removed.
Hence, one must speak either about "loop gain" (stability limit at -360 deg) or about the product Aol*beta. But one shouldn´t mix both wordings in one text.
Answer from Adam:
Fc is the cut off frequency the point where the output has fallen 3dB from the original input signal. I understood that -5.7˚ was the point at which it is accepted that attenuation starts, all though I suppose it starts from any signal that’s not d.c. I understood the -84.3˚is the accepted stop band which is 10 times the frequency this adds up to -90 degrees the maximum phase shift a single pole response can give. Is this correct?
To me, this is somewhat confusing (although correct) because this information seems to be totally irrelevant for opamp applications (always with feedback).
Well because of the op-amp input capacitance causing a pole with the source impedance you will only get 180˚ at d.c.
Lvw Said:
No. The 180deg phase shift simply results from the inverting input.
Answer from Adam:
I understand that to achieve exactly 180˚from the start the input would have to be d.c and because the input is a sine wave you will always have a phase shift although at very low frequencies it is very small. Is this correct?
OK - it seems that my first comment was based on a misinterpretation of your sentence. It is correct, that at the opamp output we have -180 deg phase shift for dc input only. However, with rising frequencies the deviation from 180 deg is caused by the frequency properties of the whole amplifier (and not only by the input stage).
A reference buffer that is unstable because of too large a resistance on the input which causes increase loop delay due internal and external capacitances and of course causes a reduction in phase margin.
LVW Said:
No - the input resistance does not degrade stability (By the way: What is the purpose of R8 and R9 ?) . We have instability because of 100% feedback (most critical case) together with an extremely large load capacitor
Answer from Adam:
The input capacitance and large input resistance can cause ringing. Is ringing not classed as a stability issue? R8 and R9 are there to show an example of a circuit that will cause oscillation on start up. The circuit is a poor voltage reference.
As an example, you have selected a circuit which never will be used. Therefore my question: Purpose of R8 nad R9?
More than that, these resistors do not degrade stability. However, the capcitor across the input causes an additional pole for the feedback factor.
Hence, we have additional phase shift for the loop gain function - and the stability is heavily degraded. In addition, the load capacitor deteriorates the situation.
LVW Said: As a consequence, Fig. 17 is meaningless because AC analysis of unstable circuits give no meaningful results, see the plotted gain of 8 dB (for a circuit that should give 20 dB gain).
Answer from Adam:
This shows what happens if someone thinks of filtering the input with a capacitor. It is suppose to show instability. Surely a.c analysis shows whether a circuit is stable or not otherwise why measure phase margin in the first place?
Performing an ac analysis (with an input ac source), requires a stable bias point and linearization around this point (made by the program). However, if a circuit is not stable these conditions are not fulfilled (either the output is clamped at the power rail, or - in case of oscillations - we have two ac sources within the circuit). As a consequence, an ac analysis for unstable circuits in closed-loop conditions are useless - the results are meaningless and false!
If a circuit is unstable, either a TRAN analysis for the closed-loop circuit is to be performed or an ac analysis for the loop gain (demonstration of a negative stability margin) .
Regards
LvW
