Dave Boland
It has been a lot of years since I have done anything with op-amps, but
I seem to recall that some devices have a min. suggested closed loop
gain. I have also seen an app-note that has a gain of about .303
(inverting input). My question is what are the guidelines on:
1. Gain range. Can it go from less than one to 10 without stability
problems. The Fbw is DC to 1000 Hz, so I'm not worried too much about
the AC aspect (unless I should be).
2. My recollection is also that I should not select resistor values much
below 10K for either Rf or Ri. I don't see this as a problem now (fixed
gain), but doesn't it present a problem with variable gain designs?
3. Finally, I believe that using a pot. as Rf is frowned on because of
the noise of the wiper. If I need to ad some trim capability to the
design, should I do this with a pot connected to Ri?
Thanks for your time and any helpful answers.
Dave,
Dave,
