The manual has been uploaded to you.
However, it has been sent using a different e-mail address than
"[email protected]."
Go ahead with whatever you'd like to do with the file.
Here it is:http://www.eserviceinfo.com/download.php?fileid=37140
Page 25 appears to be the relevant section.
- Franc Zabkar
Here it is:
By my reckoning, you would need a DC offset of 2.7V before Q552 would
turn on, and you would need 1.2A in the emitter circuit of Q552 and
Q553 in order for Q551 to turn on.
It appears that the protection circuitry is in two parts. Q551 and
Q651 sense the current in the emitter resistors, whereas Q552 and Q553
sense the DC offset at the amplifier outputs. Both protection circuits
trigger the Protect signal at pin 24 of the LM6405G microprocessor via
Q554, and the uP then trips the relay via pin 30.
Disconnecting R556 will disable the DC offset protection, and
disconnecting R553 and R653 will disable the current overload
protection on the left and right channels, respectively. Disconnecting
each of the three resistors one at a time may help narrow down the
source of the problem.
Q553 in order for Q551 to turn on. The latter is much higher than your
out-of-spec 60mA idling current.
- Franc Zabkar
Franc Zabkar said:It stands to reason that rotating the pot fully CCW or CW should not
damage the amp, otherwise not many would have left the factory. If the
trimmer is wired as below, then why not measure the idling
voltage/current at both extremities and verify whether this trips the
relay?
| V
If neither setting causes the relay to trip, then the problem must lie
elsewhere.
- Franc Zabkar
Franc Zabkar said:It appears that the protection circuitry is in two parts. Q551 and
- Franc Zabkar
OK then, how about this for a scenario. As both pots are now set in about
the same place to get the same idle current, and one of them wasn't before,
it follows that the one which was wrong, had almost certainly been set
wrongly for a long time. This means that the transistors and heatsink on
that channel have been running much hotter than they should have. If it uses
mica washers with heatsink paste, rather than silicone rubber insulators,
the excess heat may have dried the paste out over the years, such that itis
now doing a poor job, and the transistors can get hot enough to start
running away, which creates a large emitter current, which is then sensed,
and causes the shutdown. Even if the insulators are rubber, a close
inspection might reveal that the excess heat has done them no good, and they
have gone hard. Just a thought, as I agree with your thoughts regarding
offdet and current trip points.
Arfa
There are two ways to go about servicing...
1. Find out exactly what's wrong.
2. Get the device working again.
Most people smart enough to service electronic equipment tend to lean toward
the former. But it's inefficient, and should be reserved for times when it
seems to be really needed.
In your case, it appears that #2 worked (for whatever reason). I would
suppress my curiosity -- your "I don't know why, but..." -- for the time
being and simply enjoy the amplifier.
Arfa
the excess heat may have dried the paste out over the years, such that it is
Arfa
Not disputing the "should" Franc, I was just thinking that if the pot was a
bit touchy, then whacking it from one end to the other with it farting
about, might just result in the magic smoke being released from the outputs.
Just being careful, which you, more than most on here, should appreciate is
a sensible thing to do with a DC coupled amp ... d;~}
Arfa
I guess the offset is fixed instead of adjustable. And, I'm guessing
that I'm most likely wrong but, does the idling current adjustment
have any relation to and significant effect with the DC offset?
I don't know why but, after setting the idling current to factory
specs, the amp appears to be stable; the heatsink and transistors
don't run hot and the protection never trips while playing music
through it for 4 hours straight with a pair of Yamaha S55 monitors.
It never worked that well until after the adjustment was done.
And, when setting R607 to where the test lead shows 7.5mV on R ch. and
doing the same for R507 for L ch., the resistance reading were, more
or less, ended up being the same on both pots.
But, when I set R607 to a setting that ends up reading 100mV at the
test point, the heatsink gets kind of toasty and the protection kicks
in within a few minutes.
Franc Zabkar said:I was following up your suggestion that rotating a dicky pot may have
cured it, in which case returning it to its original condition would
not recreate the original fault. Furthermore, if the pot in the above
case had an intermittently open wiper, then you should be able to
reproduce the same fault by driving the wiper to the far left.
Based on the OP's followup, it appears that the pot itself may not
have been the problem.
- Franc Zabkar
Anyway, congratulations on getting your amp working.
- Franc Zabkar
I understand exactly what you're talking about, but it simply isn't
productive. There are better ways to use your mental energy.
Pots (or the circuits they regulate) can and do drift. I've bought several
of the original Sony FM Walkman, and all have required the stereo sync pot
to be readjusted (by ear is sufficient) before the tuner would switch to
stereo.
