On/Off switch using MOSFET idea needed
E
elfa
I'm building a standard LM386 low power amplifier for use with small portable
radios to amplify the sound via the earphone connection. What I need is a way
to turn on the low power amplifier JUST by using the voltage it receives from
the input (earphone jack). The idea is that the speakers circuitry will
automatically turn ON when the radio is turned on and turned OFF when the radio
is turned off. Portable, amplified, speakers like this used to be made but
apparently not anymore (I have an old one from Radio Shack...my prized
possession).
I'm thinking that a MOSFET would be the likely transistor for a job like this.
Anyone with any idea of the best way of doing this?
Any ideas or webpage link will be appreciated.
thanks
elfa
L
Lord Garth
possession).
For decades, phono jacks have been made with a switch built in. These
normally
break the speaker connection when the earphone plug is inserted. You can
use
that switch to activate your battery powered amp.
Dimitrij Klingbeil
Lord Garth said:
a receives the
normally
use
And when no switching jack is available a one-transistor-amp with a reed
relay may help.
E
elfa
normally
use
That's not what I'm looking for. I want it turned on 'electronically' when the
radio is turned on.
elfa
L
Luhan Monat
possession).
thanks
elfa
Technically, what you are describing is a 'retriggerable, one-shot,
multivibrator' (if memory serves). You want audio to trigger a timer
and the timer to only turn back off after a specified time with no audio.
This envolves amplifying the audio to a sufficient level to convert it
to a set of digital pulses that keep resetting some timer circuit. Lots
of ways to do all this with a bit of prototyping and experimentation.
W
Watson A.Name - Watt Sun, Dark Remover
You may be able to find a schematic of such a circuit by googling for
clap switch. Here's one.
http://www.discovercircuits.com/S/sou-operate.htm
This one needs some work. B1 should be a wall wart. The relay should
have a 1N4002 across the coil, cathode to positive. The R10 should be
much lower, 2.2k or 1k. As for performance, don't expect much out of
it. It doesn't have any bandpass filters at all. So noise at any
freq can trigger it. http://home.maine.rr.com/randylinscott/dec97.htm
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
E
elfa
Actually...I've already got an idea that works! In my simple test, I used 2
transistors in an arrangement similiar to a Darlington Array. Except that Q2 is
a MOSFET (IRF510), not a second NPN (904). The test was to input just the
signal from the earphone jack of a radio into the base of Q1 which had a
separate power supply and make its way from Q1's emitter into the MOSFET's gate
and light up an LED which was connected to Drain; then, when the radio is turned
off, the LED goes out, which would tell me the power is turned off. If it
worked with an LED, then it could do the same with LM386.
It works...but for one radio only (a real junker). It won't work with any other
radio I've tried.
Now...to figure out why.
elfa
L
Luhan Monat
radio I've tried.
elfa,
If you get steady light from the LED, you are probably getting some DC
offset from your radio. Serendipitous solution at best.
