Omega Race Lighted LED Switches
1
1hookedspacecadet
I am trying to wire up some led / lighted switches from an Omega Race. On
the side of the switch, it has the following info:
+ = 2V MAX
5 A125/250 VAC
Can someone help decipher this for me so I can figure out what voltage and
amps are needed to lite these up? Also, should I place a resistor in line
as well?
Thanks!
Doh!
+ = 2V MAX
5 A125/250 VAC
as well?
Thanks!
Try a VIDEO group, brainiac.
James Sweet
+ = 2V MAX
5 A125/250 VAC
as well?
Thanks!
Be careful with those switches, they're highly sought after by those who
need them because they haven't been made in years, I had to pay $25 for one
a while back. The lower rating is just the switch contacts, it's a standard
microswitch, one common, then a NO and NC contact. The other two go to the
LED, it's a standard red LED, probably should be run at about 10mA, and yes
you need a resistor which can be calculated once you know what supply
voltage you'll be feeding the LED with. The wiring should be pretty obvious
by looking at it, 3 pins on the switch and 2 for the LED, polarity of the
LED can be found by trial and error.
NSM
| + = 2V MAX
| 5 A125/250 VAC
| as well?
How many connections to the switch?
Looks like you need 2.0 VDC positive connected to the "+ = 2V MAX"
connection.
Andrew
Nice Anon post.
So you know, he posted this in video groups as well... You never know who
can answer what questions where.
But then again, why not spend some energy and spread some negativity...
Andrew
Need I say, Mom's rules? Sheesh...
1
1hookedspacecadet
Thanks to everyone who gave me useful feedback. I got this working over the
weekend.
