I have this old AC- DC transformer that is not working. I believe it has a mechanical rectifier but I could be way off base.
It does work on AC. Readings taking are about 12V AC between two taps and 7V AC & 5V AC between the other two.{center tapped}
There is a rotary switch that switches between AC an DC.
There is a drawer with coils that seem to operate points{contacts} .The metal bars that are at the top of this drawer contact brass tabs when the drawer is in place. It would seem to me this is what would make pulsating DC as the coils draw the contacts together and than release as the AC voltage returns to 0v. It looks as though someone has replaced some wires in this so I am not sure if it is wired correctly. It could also be missing some wires. In one of the pictures I labeled where 120Volts input{primary} is. I can take some more pictures if it would help. Does any one know how this should be wired?
