I have a tiny solar panel I took out from a cheap toy.
With the DMM it gives 2.744 volts at the constant lighting I have.
I took a resistor, and connected it with alligator clips, etc. I measured the TOTAL RESISTANCE across all the wires and the resistor. I got 979 ohms.
So, E = IR, and I = E/R, predicting that I should get some 2.7 mA current.
And yet measuring the actual current in series with the DMM, I only get 81 uA.
I don't understand? I measured everything again with another DMM and I get the same results. The solar panel voltage is correctly measured, the total resistor + wires measured is corrected (i.e., the entire circuit resistance minus the solar cell).
It is off by a tremendous amount, with predicted milliamps and yet actual is microamps.
