Paul said:
That confused idiot doesn't know what the hell he's talking about...When
it comes to linear electronics, and especially operational amplifier
circuits, you need to think about catalogs and directories of
standardized circuits, which can be used in various non-standard ways.
To make things more useful to the cookbook engineer, it makes sense to
refer the total circuit noise to a standardized input, the non-inverting
input in the case of operational amplifiers, and provide a gain function
from that input to the output, called the noise gain. Then the cookbook
engineer need only divide that noise gain function by his signal I/O
gain function to refer the noise to his signal input and thereby derive
a S/N for his particular application. By this reasoning, the noise gain
is by definition the ratio of total output noise to input noise referred
to a standardized input for the circuit topology under consideration. If
you don't like the idea of an assumed standardized input then certainly
you would have to take the standardized input as the one called out in
the manufacturer's specification sheet for the input voltage and current
noise density functions, and this is almost always the non-inverting
input. Call it the datasheet specified input if you don't like
standardized input terminology.
