Obsolete OEG series OUC relay
Jim Weir
Anybody got a source for some obsolete OEG relays? The series is OUC and the
full part number is OUC-SS-112D.
Physical: 10mm high by 10mm long by 7.5mm wide. Six pin case with pins on
"wide" spacing of 6 mm and "long" spacing of 3mm and then 6 mm for an end-to-end
"long" spacing of 9 mm.
Electrical: 12 volt coil @ 310 ohms (40 mA). SPDT contacts for audio (dry
circuit) switching.
I only need a couple of dozen to keep some 20 year old equipment working for the
next few years. If anybody has any sources, please advise.
They strongly resemble the Omron G5V but are about 2mm shorter and just enough
that the pins won't quite stretch without redrilling the board.
Jim
