Nuts for BNC/F connector
SioL
I've been searching for a cheap supplier of nuts,
its the type used in those cheap chassis-mountable BNC
female connector or F connectors.
Surprisingly its not so easy to find them. Need about 1000 pieces.
I've got one supplier only and am looking for possibly cheaper
alternatives.
SioL
whit3rd@gmail.com
female connector
The thin material of those nuts means they aren't generally used
as fasteners for other purposes; and for BNC connectors, the
nuts are sometimes important parts of the connection, come in
exotic silver-plated variants. Cheapos are nickel plated brass.
3/8-24 nuts just a little thicker (jam nuts) are available from
use-enco.com
for a few dollars per hundred. Part number 325-3267.
I've seen steel nuts of that type in lamp assemblies, so maybe a l
ampshade shop
would be able to get you some thinner ones.
Michael A. Terrell
alternatives.
SioL
3/8" * 32 thread are used on standard 1/4" shaft potentiometers.
BTW, do you have a local cable tv company? Some throw away piles of
these nuts removed from "F-81" bulkhead adapters when used for a simple
splice. Their passives suppliers also sell cheap bags of replacement
nuts.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Peter Bennett
alternatives.
AMP sells them separately from the BNC connectors - available through
Newark. (I was surprised recently when I ordered some AMP panel/pc
mount BNCs and they came without nuts or washers - nuts and washers
had to be ordered separately, but that wasn't apparent in the Newark
catalog.)
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
RST Engineering \(jw\)
Google "Keystone" and "HH Smith". Both of them carry radio pattern nuts of
this size and both of them have European sources.
Jim
John Woodgate
dated Thu said:
Looking for EU-based supplier.
You may find that a bit more difficult, because EU pot bushes are often
now 10 mm, not 3/8 in.
