Chris F.
Got this set in the other day, don't have the model number handy but it
was made in Feb. '95. It had been looked at by another shop, they had given
the owner an estimate and then the owner died, and the guy who "inherited"
this set brought it to me. I knew the tech at the other shop, and phoned him
up to see what his diagnosis had been. He said it needed the whole power
supply / horiz. output module replaced, at a cost of $300 Cdn. The guy is
competent but I decided to have a crack at it anyway.
The set had sound but no HV, and the HOT (and some fuses) were blown. When
I tested the flyback on a homemade tester (built from the plans on the
repairfaq site) it was arcing badly between the pins on the flyback.
Something told me this was not right, so with the customers permission I
ordered a new FBT. Sure enough, the old flyback was indeed defective. Once
the new one was installed, the set powered up - for about a minute. It seems
to have a decent picture and everything, but if the G2 control is turned up
anywhere past minimum, or if a bright scene comes on, the horizontal drive
is shut down. The high voltage stays within 25kV so I don't think this is
the cause. Turning the set off, then on again, cures the problem until the
next bright scene.....
Considering that the set was "worked on" by at least two other shops, I
fear there may be some unknown damage done by a technicians carelessness. I
already repaired some cold solder around some connectors.
Any ideas? I'm so close, I don't want to just give up on this thing. Plus
I'd like to get the it done and out of there - this monster takes up half my
shop!
Thanks.
shop!
Thanks.
