G
George Herold
NPO ceramic vs polypropylene
There was a little side discussion on JL’s LC tuning thread. When I looked at this ~2 years ago I found that ceramics were a tad better than the ‘good’ poly-pro’s.
(I used them in a low freq LCR circuit.. Q~35 so the cap type didn’t makethat much of a difference.)
(The poly pro’s I have are from Panasonic. low dissipation 2% caps. I can dig up a part number if it’s important, I’m not sure they are made anymore.)
So these are both 10nF caps. I first measured them on an SRS720. at 10 and100kHz.
10kHz 100kHz
type C R D R D
NPO 10.17 0.6 0.0004 0.006 0.00003
poly 10.16 0.23 0.00013 0.086 0.0056
The R/D numbers are so low I don’t really believe them.
So I stuck the C’s in the (original) LCR circuit. So I list peak frequency, Vin and Vout. (As measured on a ‘scope (digital w/average))
type freq. Vin Vout
NPO 6.08kHz 159mV 6.40V
poly 6.13kHz 159mV 6.36V
(again no real difference to talk about.) I pulled out a different L...
type freq. Vin Vout
NPO 157kHz 91.2mV 7.36V
poly 158.5kHz 92.8mV 7.24V
Finally a bit of difference I can believe. Vin dropped because the series LC was loading down the function gen.
So for those who think film are better, you might want to look again at NPOceramics. They've improved a lot*. Of course this says nothing about theDA of the caps. (How does one go about measuring that?)
George H.
*you need to get the new little ones.. the old larger npo ceramics with thedull brown coating are not nearly as good.
10kHz 100kHz
type C R D R D
type freq. Vin Vout
type freq. Vin Vout
George H.
