NPN - linear or saturation region region for GPIO switching
  • Thread starter sridhar09.cherukuri@gmail.com
  • Start date
I am using a general purpose BC846 NPN transistor collector to pull an IC'sEnable pin down. The base of BC846 is driven a source that can only source0.2mA of current. Since I only need to turn ON the transistor to pull the Enable pin down, base drive of 0.2mA is sufficient. Is 0.2mA of base current sufficient to fully turn ON the transistor or it will operate in the linear region? What will be the power dissipation if the transistor is operatedin linear region compared to saturation? The system may be in this state for several weeks. Are there any potential issues if the transistor is operated in this way.
thanks
srcherukuri
bloggs.fredbloggs.fred@gmail.com
I am using a general purpose BC846 NPN transistor collector to pull an IC's Enable pin down. The base of BC846 is driven a source that can only source 0.2mA of current. Since I only need to turn ON the transistor to pull the Enable pin down, base drive of 0.2mA is sufficient. Is 0.2mA of base current sufficient to fully turn ON the transistor or it will operate in the linear region? What will be the power dissipation if the transistor is operated in linear region compared to saturation? The system may be in this statefor several weeks. Are there any potential issues if the transistor is operated in this way.
What textbook are you using? Anyone who would think enough about those various issues would not be so ignorant of the answer.
What's the pullup resistor value, to what voltage?
Shouldn't be a problem as long as the max collector current is a mA or
two. It will saturate to a tenth of a volt or less.
John Larkin Highland Technology, Inc
jlarkin at highlandtechnology dot com
http://www.highlandtechnology.com
Precision electronic instrumentation
Picosecond-resolution Digital Delay and Pulse generators
Custom laser drivers and controllers
Photonics and fiberoptic TTL data links
VME thermocouple, LVDT, synchro acquisition and simulation
Thanks for the response. Pull up is 330K to 16V.
This depends on how much current the IC pin might source. I know of no
modern IC's that would source enough to cause problems, but if you're
using something oddball you should check.
That depends on what's hanging off of the collector, and on the
transistor. If you load presented by your pull-up resistor and the IC
pin sources less than 2mA when the collector voltage is 0.2V, then it
will almost certainly be saturated. It'll probably be saturated with
higher collector currents, but that depends on the transistor in question
-- check the data sheet.
Well, transistors, like all other physical objects, follow the laws of
physics. The power dissipation of the transistor will be equal to the
collector-emitter voltage drop times the collector current, plus the base-
emitter voltage drop times the base current. So the dissipation will
depend on the CE voltage drop and the collector current, and you haven't
given enough information for anyone to predict those values.
Check the allowable dissipation of the transistor, and compare that
dissipation with your calculated dissipation. If the calculated value is
less than the data sheet value by a healthy margin, you're OK.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
The collector current is always limited by few tens of uA due to high valuepull up resistor and the IC pin internal limitation. Base drive is max 0.2mA. With this limitation of base current and collector current will the transistor ever reach saturation? If it doesn't, will operating it in leaner mode continuously for long periods cause any issues due to high Vce?
josephkk
Thanks. BC846 must sink about 50uA.
You are extremely unlikely to need any more base drive than collector
current. You could probably cut it the 1/10 of required collector
current.
