Sir fiveseven15 . . . . .
Certainly . . . . if you help . . . . first of all , about that wire, of which you removed the black “pookie” deposited around part of it, to reveal a connected wire.
Is it being a wire that is being formed as a “U” loop and then bent around and passing under a white wire tie and finally terminating at the BLACK and WHITE wires terminals? E.g. a wire jumper.
OR is what looks like a loop, ACTUALLY being the metal housing of a photocell that is passing thru a hole in the plastic housing and the wrap around plastic tie serves for holding the photo cell case in place?
Further testing related to those two connections, has to be put on hold, awaiting for your response.
Refer to post #3 and the 2nd photo down and MAG it on up, and then note its central 1/4 in shaft, is there a hole just below it, and does it have the exposed terminal end of a NE-2 glow lamp showing, with its tip end having been pushed down within the hole ? This would be the point that you could catch the orange glow of it, if it was being powered up and illuminated.
If all is true so far, would its wires be connected to the screws that go to RED and GREEN wires ?
(GAWD . . . . that’s one awesome pic . . .if you’re displaying it MAGGED on a 42 inch HD monitor . . . . so modify that to one 21/64ths inch length, and another 19/64ths inch length set of black cambric spaghetti insulated wires, that are insulating the NE-2 lamps bare leads.)
If all holds true so far, no ohmmeter needed now, you will be using metering set for AC voltage in the 50-100VAC range.
You will be connected up and metering across the RED and GREEN and expect in the 65-75VAC range of voltage being metered across them, if the unit is turned on.
It should receive one end of the AC line at GREEN wire terminal and a voltage and current limited power feed thru from a 100K resistor at it’s other RED wire terminal .
Lastly I need the alpha numerical identification from the Triac to positively confirm its specs and terminal layout . . .it is just being marked randomly now.
Thasssssit . . . . .
73’s de Edd
