I implemented this circuit and am getting the output desired but what I observe is that if I dont connect anything across the Zener diode (i.e. if I remove everything after the capacitor connected parallel to zener diode) i'm getting a constant a 12V but if I connect everything I dont get a 12V across the Zener voltage regulator, basically there's a voltage drop.
Could you pls help in identifying where I'm going wrong or maybe I have chosen some wrong value of resistor or capacitor somewhere which is causing this drop, because I need a 12V across the zener voltage regulator when everything is connected.
