Normally closed glass reed switches
H
Heywood Jablome
Just looked at RS, Jaycar and Dick Smiths,
I'm looking for a glass reed switch that is normally closed. Can't seem to
find a supplier that has any for a decent price.
I need 50 of them and while most people dont stock them, RS wants over $4
each. Im too tight to pay that much as I can see that Electus has the
normally open variety well under a dollar. (but no normally closed ones)
Anyone have any other suppliers they care to share?
atec77
They come in the elcheapo DS alarm it so they must be available . I
sourced some a while back from direct alarm supplies at a very
reasonable price .
K
Kevin Martin
Well if I look at DSE page and do a search for reed switches. The top of
the list is a N/C one for $1.50 (P7856). What's the matter with you? I'm
sure they will do a better price for 50.
Kevin Martin
H
Heywood Jablome
Kevin Martin
Thanks Kevin but the search continues. The Dick Smith reed switch is
normally closed in the presence of a magnet. To me this means that it is
normally open in its normal state (form A). Some may disagree with my
terminology.
In any case I need one that stays closed when not in the presence of a
magnetic field, and opens when a magnet is brought towards it. This is a
little harder to find but its not impossible. I purchased a Form C reed
today from RS components. At over $6 it was OK for one prototype but not
good enough for quantities of 50 plus. (they only give you a dollar off at
25 units)
So the question remains where I can get a normally closed glass reed switch
at a decent quantity price sub $1.
H
Heywood Jablome
sourced some a while back from direct alarm supplies at a very reasonable
price .
I think you are talking about the plastic box ones. I'm after the glass reed
insert that is inside them. Just the insert, not the casing. I don't think
DAS would have them.
H
Heywood Jablome
price .
sam
If worst came to worst, could your application use a transistor inverter circuit with a normally
open switch?
Cheers,
Sam
atec77
no , ring them and ask
ring them and ask
I don't think
I believe you
H
Heywood Jablome
ring them and ask
I don't think
I believe you
No worries. I'll call them, thanks.
John Dunkley
It is possible to 'bias' a NO reed switch with a small magnet to make it NC,
and then use your main magnet to bias it off.
I know this works because I have done it.
Just need a supply of small magnets and position it to bias the reed switch
on.
JD
two bob
Jaycar has them (cat# SM-1002) the 25+ rate is $1.20 AU each,
SM1002 is a N/O switch.
It may be easier to find a changeover than a N/C
Mark Kelepouris
Jasen Betts said:
Jaycar do too.
How about using a reed switch that's open in the absence of a field and
gluing a small ceramic magnet near the reed to close it so that an
opposing magnetic field can cancel its field and open the reed switch.
I like your lateral thinking Jasen, it would be interesting to know if that
arrangement would make a reed switch last longer or shorter.
Mark K.
two bob
that arrangement would make a reed switch last longer or shorter.
Sounds very hit and miss to me, and very unreliable.
