ngdbud
Hey guys, after searching the web for some simple schematics, I found
this 8 watt amp that would be perfectfor me as a beginer (based mostly
on the number of components) http://www.aaroncake.net/circuits/amp.htm
There are just a few things that need clarifying for me.
1) The IC doesn't have pin numbers labled and it's beyond me to figure
them out.
2) Only one wire is labled input. Does this mean I attach one wire to
this input and the other to the same ground used for the negative
power? If so, does it matter which wire I put where since sound travels
as AC waves?
3) This says it's an 8w amp, but would it be a good idea to plug in a
10 watt speaker just in case? and which would give me better or louder
sound, a 4 or 8 ohm speaker?
I've had enough minor experience to understand the rest of this
circuit.
Thanks in advance!
them out.
as AC waves?
circuit.
Thanks in advance!
