ok so, set your meter to ohms range and select a suitable setting ohm range on the meter and put your probes across each side of the capacitor, if the cap is ok ul see the resistance increase slightly ul have a reading at least.
if the cap is gone the reading will be 00.
The range fluctuates idd and increases 700 mhohm (range autoselect) difficult to hold the points longer then a few seconds.. Thanks.
