Glad it worked out for you.
All the best.
Martin
All the best.
Martin
Thanks for sharing.
Martin
Let's hope he is being civilized rather than a bad smell and maggots entering your property.
Although I cannot condone your actions, I am glad you sorted it out.
Martin
Thank you for this valuable informationRegarding running the board and motor from the same power supply. If it gets too warm, change it for a higher amperage ie: 3A for a 5A adapter.
Double sided tape will depend on the quality and location. I’d probably drill a small hole either side of the board into the housing and put a zip tie (cable tie) around for good measure.
Maybe one day you could share the reason for needing a jackhammer on the ceiling.
Martin
Martin
