No Voltage Release switch "NVR"
Speedskater
Is there any US equivalent to a "No Voltage Release" switch?
Kevin
remove the zeppelin to rely.
Prepair Ltd
Kevin
You can make up something similar with a contactor with holding contacts and a
single-push reset switch. Contactor is started by closing the single-push reset
switch, holding contacts hold it on (!) if the supply fails it will not close on
supply restoration unless the reset switch is pushed.
A lot of motor starters have this feature as standard.
Peter
Speedskater
Peter
Peter A Forbes
Prepair Ltd, Luton, UK
[email protected]
http://www.prepair.co.uk
I know.
That's what we first thought of in another group.
Then someone in the UK suggested using a NVR switch.
See:
http://orion.quicksytes.com/viewtopic.php?t=436&postdays=0&postorder=asc&start=15
Kevin
