Phil Allison
"Mark Harrarse Lying Criminal Retard"
** That sounds like a magnetic ballast fluoro lamp with replaceable compact
tube.
Not the same thing at all as the **electronic ballast** 240 volt CFLs that
we are all being forced to use these days.
** An outdoor dunny light gets used maybe 25 minutes a day - would have
clocked up only 2000 - 3000 hours in 15 years.
Magnetic ballasts go on for ever and the tubes are of quite different and
much longer life design compared to electronic ballast BC and ES type CFLs.
No comparison exists.
** Is there a ***standard BC or ES fitting ** on the fucking thing or not
Model number and / or pic IS required.
But obviously is NEVER EVER coming from a rabid fucking nut case &
criminal piece of trolling shit like YOU.
As is being proven over and over.
.... Phil
I have an old Philips 15W unit with a rounded cubical base and four
straight parallel tubes coming out that join at the ends to form the
ionisation path.
tube.
It's been running fine in the dunny for more than 15 years.
The base measures 40mm cubed and has "Electronic" written on the side,
total length is 20cm.
.... Phil
