Following Kees suggestions I have the yeoman working and have data, but
I can't send waypoints to the chart plotter from the yeoman, also I
don't seem to be able to benefit from data for winchart on my pc?
My Yeoman XL pinout data shows:
Data Spec
NMEA 0183 4800 Baud
8 Data
No parity
1 stop
NMEA 0183-1 As NMEA 0183 (Adds 100 to waypoint number on output)
NMEA 0183-2 As NMEA 0183 (Adds 200 to waypoint number on output)
NMEA 0182 1200 Baud
8 Data (MSB set to 1)
Odd parity
1 stop
Navstar 2000 110 Baud
8 Data
No parity
1 stop
These are the speeds it runs when it is set to the various output data
streams. Make sure your multiplexer and chartplotters are set to the
correct speeds to receive it. Mine wasn't and it took a while. I had to
slow the whole boat's 0183 data streams down to 4800 baud, 8-N-1 just to
get it all to listen to the slow Yeoman data stream to get waypoints. It
won't run 9600 baud, darn it... At 4800 the system seems to be plenty
fast..... Your Yeoman manual shows how to switch output data streams
between these. Ours is set to 0183-1 adding 100 to the waypoint number so
I can see on the chart plotters and computer all waypoints in the 100 range
came from the Yeoman, not the plotters or computer. Reduces (but doesn't
eliminate, of course) confusion....sort of....(c;
Another Yeoman issue is:
Voltages
O/P voltage TTL levels (0-5V)
Sources 50 mA
Don't hook it anyplace else but the multiplexer or the TTL voltage will
suffer driving two loads. It'll only put out 50ma...output.
System:
Raymarine RL70CRC-H radar display/chart plotter
w/Seatalk gyro-compass, WAAS-GPS, (compass normally off NMEA bus)
Garmin 185 chart plotter/sonar (backup GPS normally off NMEA bus)
Noland NMEA 4-port multiplexer
Icom M-602 VHF DSC
Icom M-802 HF-SSB-DSC
B&G "Network" (NMEA 0183) instruments, Pilot, Data display, compass sensor
(better than Raymarine's)
Yeoman XL boards removed from portable foam lap board and mounted to bottom
of mahogany chart table top to energize chart table....firmware upgraded...
Let me know if you want to know what I did to get the Yeoman to work under
the chart table. Works great without the Yeoman's workspace cluttering up
the place...(c;
Larry - 3rd mate, engineering
S/V "Lionheart"
(Amel Sharki 41 ketch)
Charleston
It's not mine but I get to play with it when the head is stopped up....(c;
