ASAAR said:
On Tue, 27 Sep 2005 21:53:02 +0200, imbsysop wrote:
I'm fully aware of the formula and what it represents, at least
mathematically. But this is not the proper forum to discuss
integral calculus and derivatives. But your point that it was
"probably the same thing the Maha guys mean ..", and was also
referring to FLEX negative pulse charging seems to be incorrect.
Are you saying that all of the smart chargers that monitor "-dV/dt"
use pulse charging circuits? I thought they were used only by some
of them. And that not all of those also utilize negative charge
pulses. If I'm mistaken could you provide some documenting links?
A year or so ago, I bought the MH-C401FS battery charger with "FLEX NEGATIVE
pulse charging" feature. I wanted to find out what their charging procedure
was that produced such good results. I have a chart recorder that will trace
a line on a paper graph at an adjustable speed of paper movement. The
process I wrote in my notes is as follows:
"As soon as a battery is inserted in the holder, the controller switches
1000 mA charging current through a cycle of 1/4 sec on, followed by 3/4 sec
off, and it does this for 66 seconds before settling down to a nearly
continuous charge rate. I say nearly continuous because the charging is
switched off for 9.6 milliseconds four times per second. This continues
until about 50 minutes into the charging process when the charging current
is turned off for about 1 minute, and then continues for another 50 minutes
or until the charging process is stopped by the detection of a slight drop
in battery voltage, at which time the green light is lit and the charging
switches to a trickle charge by turning on the 1000 mA for only 1/4 second
every 4 seconds. So that's what happens to the current - - but I have no
idea when the microprocessor looks at battery voltage."
The chart recorder was set to display zero current at chart center so that
any reversal of current that might be described as "Flex Negative charging
current" would be displayed as a negative value. The charging current never
went negative! But this run was done on a set of new cells, so maybe the
"Flex" part didn't need to be executed. I can imagine applying a momentary
resistive load would result in a "negative" pulse of charging current, so it
might happen, but I never saw it.
Chuck
