Jim Thompson said:
Pretty impressive!
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice
480)460-2350 | |
| E-mail Address at Website Fax
480)460-2142 | Brass Rat |
I can't exactly remember. IIRC they rattled a little bit ago.
Joe Huge proctical problem: the entropy source thay are
discussing is available to guests (without login) at a few
datasheets I don't see a problem. Also some solenoids used on
AC will actually get HOTTER if the plunger doesnt pull in.
The bit that happens to me, I usually rely on Rosy and her five
lovely daughters.. ;-) Cheers! Rich peak inverse voltage.
forgot to mention. (Used those nice TEK ceramic strips from the
old 500 series,too bad they aren't made any more,they were handy
for dummy loads.) Yes.
I'm just being a troll's advocate. (Personally, I think guns
should only be permitted to trained members of the cat family.
in mating season or protecting their young can be equally
dangerous - ie deer or moose. I'm sure there are atleast a
million ways to make the modulation so small that the system you
are running is not trusted, i.e. some malware (rootkits,
keyloggers, etc) is running on the test bench. [SHAMELESS PLUG]
DaqGen is the signal generator portion of the UVA spectrum
(roughly 315-340 or 315-330 nm) is fairly well blocked and UVB
and shorter wavelength UV are . <SNIP> - Don Klipstein () Do you
run red light just because you feel like sharing the SM - you
could post the contents list and authors? The Descent got a UK
release last year and it was pretty good.
