Malcx
Hi all,
I've not dabled with any electronics since High school (about 10 years)
and have a fairly specific requirement for a detector that I want/need
to put together....
Background:
My storage tank leaked and ruined the flooring - the plumber couldnt
find anything obviously wrong with the tank but replaced the pieces
that showed signs of wear and we've had no obvious leakage since...
Now before the floor is re-laid I want to be doublly sure there no slow
leak going on...
As the storage tank gets warm, any surface (i.e. detectable) water will
evaporate pretty quickly while other moisture will seep out of sight
and do damage...
Specification:
I envisgae all being contained in a small box with probes coming out on
lengthy wires.
The box will have an LED that is permenantly on when the battery has
power (I'd envisage a 9v cell...)
There would need to be 2 or 3 moisture detection probes, when any 1
probe registers moisture another led on the box will be lit. This led
remains lit even after the probe dries. Only 1 led will be needed for
all of the probes - i.e. there does not need to be an led for each
probe.
A reset button will be required to reset the state of the device back
to "power led on only" mode.
(Ideally the sensitivity of the probes would be adjustable)
Can anyone help me with this seemingly simple circuit design? (I can
fit it all together, pcb design etc once I've the circuit diagram)
Thanks for your help in advance!
Mal
to put together....
Background:
leak going on...
and do damage...
Specification:
lengthy wires.
probe.
Mal
