Get good and wet. You'll feel it, and it can be torture.
30VDC No sensation. Supply leads 1/2 inch apart on my palm in a puddle of
saliva
You missed the sarcasm there.
No, I ignored it. A single cell battery is commonly referred to as, "a
battery".
Wikipedia, IIRC, is written by whomever might want to contribute an
anecdotal reference. Hence, easily infiltrated with old wives tales.
Okay, How about Ohio State Univ. ?
(2) AC is said to be four to five times more dangerous than DC. For one
thing, AC causes more severe muscular contractions. For another, it
stimulates sweating that lowers the skin resistance. Along that line, it is
important to note that resistance goes down rapidly with continued contact.
The sweating and the burning away of the skin oils and even the skin itself
account for this. That is why it's extremely important to free the victim
from contact with the current as quickly as possible before the climbing
current reaches the fibrillation-inducing level.
The frequency of the AC has lots to do with the effect on the human body.
Unfortunately, 60 cycles is in the most harmful range. At the house voltage
frequency, as little as 25 volts can kill. On the other hand, people have
withstood 40,000 volts at a frequency of a million cycles or so without
fatal effects.
A very little current can produce a lethal electric shock. Any current over
10 ma. will result in serious shock.
Summary
Voltage is not a reliable indication of danger because the body's resistance
varies so widely it is impossible to predict how much current will be made
to flow through the body by a given voltage.
The current range of 100- to 200-ma, is particularly dangerous because it is
almost certain to result in lethal ventricular fibrillation. Victims of
high-voltage shock usually respond better to artificial respiration than do
victims of low-voltage shock, probably because the higher voltage and
current clamps the heart and hence prevents fibrillation.
AC is more dangerous than DC, and 60-cycle current is more dangerous than
high-frequency current.
Look, I have been bit enough times to know from first hand experience that
AC feels different than DC. I prefer DC.... They don't call it "Hertz"
for nothing
If you don't believe it, try it for yourself. Use your variac 90VDC Vs.
90VAC @ 60Hz. Please, have a trusted friend handy to flip the switch on
and off, quickly, for you. go across the palm of your hand...
Report back what felt worse...
