I am trying to create a simple circuit with an led in it. My setup is as follows:
I connect my positive terminal of my battery to the battery inputs on the right and then i bridge from the battery to the 1st set of pins with a resistor. Then i bridge the middle with an led. I then connect the negative terminal of my battery after the led.
The above seems to work fine...However if lets say i move the led to the 2nd set of pins and put a wire where the led was...the led does not light up.....why not?...puzzles me...
Then trying to put a pcb switch in place of the wire....nothing happens, i press the switch, hold it...no lights...
So i remove the switch and put the led back to the old position....and it lights up....
Any advise would be greatly appreciated.
Regards,
Regards,
