Hi guys
Firstly I have no knowledge whatsoever of Electronics and RF, my background back in the UK was electrical but I specialized in the manufacture design and installation of Electric Heat Trace Systems for tanks pipe lines etc
I recently purchased
http://www.ebay.com/itm/2KM-Long-Range-RF-link-kits-w-encoder-and-d...
For a project imp trying to develop
Basically I have a fluid level float switch with 3 independent reed switches that when the fluid rises/falls to the 3 individual points they draw together and form a circuit
Example
Float 1 High level
Float 2 Ideal Level
Float 3 Low Level
The float switch itself will be mounted some 50 feet from the main equipment (pump and control panel)
Hard wiring between those 2 locations would be completely impractical, so I have gone down the thought pattern of RF wireless control
The float switch would sit in a bulkhead with a small weatherproof box on the top containing the transmitter and transmitter power supply and around 50 feet away in another weatherproof box would be the receiver with its own power supply
With the help of a fantastic new friend in Chennai (India) I have managed to get to the stage where the connections for the 3 reed switches to the transmitter are ok and the pairing between the transmitter and receiver also.
But honestly I don’t want to keep pestering him, even though he doesn’t mind.
My question is regarding the best power supply to the transmitter (remember no hard wiring)
So I'm assuming a battery supply contained within the weatherproof enclosure and I believe I need 5 volts?
Then secondly would be the power supply for the receiver (this can be powered by a hard wired device as its in an area where it would be practical
I'm sorry to be a pain and burden you people but your help would be greatly appreciated
Example
Float 1 High level
Float 2 Ideal Level
Float 3 Low Level
