Hello all, first post here and I'll start by saying that my knowledge of electronics is really very basic. I can take stuff apart, look for anything obviously broken and (badly) solder but beyond that I am lost. Please pitch replies as if you were talking to a 10 year old. Not even a particularly bright 10 year old.
My wife has recently acquired a pottery wheel which, on closer inspection, appears to date from the early 70s. Apparently it was working before being moved and now isn't, so I thought it was worth taking apart to look for anything obvious.
I think I have found the component at fault but am now stuck as I don't actually know what the component is or what to try next. I have attached a picture of it.
When the power is applied and a switch elsewhere on the machine is pressed, I believe the contacts on this should flip over (up in the picture) and complete the circuit, suppling power to the motor which is then driven by the pedal. In reality, nothing happens.
If I push this component up manually, it will click on and stay on and pushing the pedal will then operate the motor. Happy days.
However, when the power is cut, it clicks off again. and the only way to get it going is to manually push this component again to complete the circuit.
None of the wires on this component itself are loose, nor are any of the other wires, as far as I can see.
Any thoughts on a) what is this component? b) is it repairable / replaceable? c) is it easier just to bypass it?
Thanks in advance.
Thanks in advance.
