Are there any designs out there for an electricity meter capable of
very accurately measuring electrical power consumption, non
intrusively?
Basically what I'd like to do is either build or buy some sort of clamp
probe the could be attached (or wound??) around the insulated live wire
of a domestic power cable, then by (presumably?) measuring the strength
of the electrical field generated by the current flowing through the
wire, determine and log both voltage and current, and hence electrical
power.
This seems like an ideal application for a PIC and data logger. The
only part I know nothing about is the clamp probe to the mains cable,
and how you would convert the measured electrical field into voltage
and current. How do you stop the presumably equal and opposite
electrical field in the neutral wire from interfering with the
measurement, if the wires are close together and can't be separated?
Is this idea feasible? Has anyone got a circuit diagram? I don't want
to buy a complex and expensive power analyser, or have to touch the
wires in the circuit under measurement.
intrusively?
power.
