Tom Cumming
(Apologies for the multi-posting - I've had no replies at alt.video.vcr
so am trying here.)
About 2 years ago I bought a Philips DVP620VR DVD player & VHS recorder
combi machine. The VHS side of things has only been quite lightly used,
and playback quality was always good, until about 2 months ago, when one
day I went to use it and found it was playing "slow" - snow all over the
video image and the sound playing back wobbly at half speed and pitch, as
though the machine thought I'd given it a tape recorded in Long Play when
I had not. This affected both pre-recorded tapes and stuff I recorded
myself, but only when actually playing - the snow goes away when the tape
is paused or ff/rw.
I bought an extended warantee, so I took it back to the shop (Richer
Sounds, UK) for repair. When it came back, the paperwork said all they had
done was cleaned the heads, but sure enough it was now working fine.
I then did not use it for about a month, and found after this time the
problem has returned. Not wishing to cart it back to the shop
unnecessarily, I tried a head cleaning tape, which helped, but the next
morning the problem was back again.
Now I understand that heads need to be cleaned but this is a bit
ridiculous. If I take it back to the shop again I'd imagine they'll just
clean the heads again. With every other VHS machine I have used, dirty
heads have caused a slow, gradual degradation of playback over time, not a
sudden change from excellent to unwatchable overnight.
Does anyone have any experience with this machine? Is this a known issue
with it, and does it have a fix? Or can anyone suggest anything else I
might try, apart from hassling the shop and trying to get a refund /
replacement model?
Thanks in advance for any help.
so am trying here.)
is paused or ff/rw.
replacement model?
