Hi Folks!
I've googled this and haven't really found anyone asking the same question, so I wanted to ask here.
I do know what voltage, resistance, and current are, familiar with Ohm's Law and how to calculate Watts, but just had a nagging question and figured that someone here might have a good answer for me.
As I understand it, 1 Amp is approx. 6.2x10e18 electrons passing a given point in one second.
So given that definition, why is 1 Amp current draw at 12 volts any different than 1 Amp current draw at 120 volts? If electrons were counted passing through either circuit, both should have approximately 6.2x10e18 electrons moving by a chosen point in one second, right?
Obviously, one circuit draws 12W and the other 120W, but I would love it if someone could reconcile this with the above definition of an Amp.
I must be overlooking something very simple. Thanks for any insight you all can provide, and thank you for taking the time to check out my first post.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
--Eric
--Eric
