Hi all, I'm new to the site and and this is my first post/problem and am trying to teach myself electronics in order to revive faulty home audio equipment as a hobby. I would say I have good basic knowledge of electronics and have already used various resources to self teach myself but have come a bit stuck with my current project.
Previously I have repaired units by visually checking components and removing them from the pcb in order to check they are functioning correctly but my current project has no obvious signs of faulty components and so am going down a new route which is to track the voltages accross the board to find the problem. So here goes...
The amp is a Linn Majik-I and it works fine for about 5 minutes when it cuts the sound off. If I leave the amp turned on it never resumes the sound but if I turn it off for a minute or two and then back on, the sound comes back on again for another minute or two.
To me this points to an overheating component issue. but what do I know![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The power and display stays on so don't think it's a power supply issue
The amp does have both over current protection and over temp protection but if the system over temps it is supposed to adjust the volume by - 1db at at time and keep attempting to resume the sound, it does not do this and I have checked the temp of the thermistor and tested this and all looks ok. (it is a 33k thermistor which reads 33kohms at room temp).
I have checked the transformer outputs both before and after cutout and the voltages stay the same, as do the main Opamp chips Q301 & Q302.
Today I have started to look at the transistors on the board and have found a possible clue as to the problem but dont know why this is happening.
testing U301 U302 & U303 I get the following approx readings both before and after the sound cutoff:
U301
in 39v
out 25v
adj 24v
U302
in -39v
out -24v
adj -24v
U303
in 25v
out 14v
adj 14v
but U304 has different reading before and after the sound cuts off
before after
in -25v -25v
out -8v -3v
adj -7v -3v
is this a sign of a faulty transistor or is something before this stage having trouble?
Ill upload the schematics in a mo when I work out how to
Kind regards
Key
U301
in 39v
out 25v
adj 24v
U302
in -39v
out -24v
adj -24v
U303
in 25v
out 14v
adj 14v
before after
in -25v -25v
out -8v -3v
adj -7v -3v
Kind regards
Key
