Newbie: Digital Sensor Question
Mark Everett
I know nothing about electronics at the moment but I am looking into
pursuing a personal project.
Does anybody know if there is an off the shelf product which can
determine the xyz position of a tagged object within a 5x5x3 metre
range. So I just mean a sensor and a small digital tag which can be
fitted to/inside an object. Then I want the sensor to detect where the
tag is in relation to the sensor.
I want to be able to read the location (offset coordinates anyway)
into my pc initially.
If there isn't anything already on the market to do this
a) is it possible/hard and what do I need?
b) will i require a high degree of electronics knowledge?
Any information would be much appreciated.
Cheers
Mark
K
Kyle Miller
Cheers
Mark
Well first of all you need to decide whether any physical object like
an arm can reach the tagged object. I assume by 5 meters you likely
want wireless measurement. I am not aware of any commercial device
like that. Light waves, RF radio waves could work. Something like a
high-powered metal detector with three seperate coils (x,y,z) that
measure phase shift of a known mass of metal would probably be the
simplest way to build it.
Kyle
E
Ewan Sinclair
You could potentially use colour tracking and have cameras on 2 walls. The
only easy way *I* know of to do this is to use Cycling74's Max/MSP, which
has a feature to do it.
Also, I don't know just how innaccurate it would be in the capacity you want
to use it, but you could always pair up a 3-axis accelerometer with a
wireless serial transmitter, then just start the thing off at the same point
in the room each time and reset the coordinates. I have no idea if this
would work though, I've never tried it. The things might not be sensitive
enough.
Ewan
