NEWBE
HAPPYNEWYEAR: BILLG HERE;I HAVE A QUESTION.I HAVE AN LEI-4 XFORMER ONLY MINE IS PC MOUNT ITS NUMBER IS 430-0002E-LIE-4:E154515 CLASS 130(B) Z152D. + IT HAS 6FO1..WOULD ANYBODY HAVE INFO ON THIS.SUCH AS THE PRIMARY AND SECONDARY PINOUT..I THINK IT IS SET UP FOR 120V AC.AS THERE ARE 2 PRI WINDINGS USED.IT CAME FROM AN APC X1300 UPS.I WAS GIVEN 5 BOARDS FROM THESE UNITS.
I FOUND THIS WEB SITE SO HI TO EVERY ONE.AND THANKS IF ANY HELP
BILL-G
[email protected]
Aaaagh my eyes are bleeding!
However, thanks to http://www.convertcase.net/ I can translate...
Happynewyear: billg here;i have a question.I have an lei-4 xformer only mine is pc mount its number is 430-0002e-lie-4:e154515 class 130(b) z152d. + it has 6fo1..Would anybody have info on this.Such as the primary and secondary pinout..I think it is set up for 120v ac.As there are 2 pri windings used.It came from an apc x1300 ups.I was given 5 boards from these units.
I found this web site so hi to every one.And thanks if any help
Bill-g
I'll take another look when my eyes recover.
Lay off the caps.
You say it has two primary coils? Then it is probably rigged up to run from either 240V/120V. Depending on how it is wired.
Change the font size on your browser. CTRL and + do this in some browsers. (CTRL and - reduce it again).
All caps is simply very hard to read and many people will simply ignore the message.
