I have been trying to figure out how to build a kicker to be able to launch a metal pinball type ball with a decent amount of speed and force. The closest projects I have seen is a coil gun. I am half copying a couple of projects I saw and have ordered a few parts. (I am not well versed in electronics yet) I need help selecting a thyristor/smc.
I ordered the following:
63v 2200uf Capacitor(s)
A solenoid - Model JF-0826B -Rated Voltage: DC 12V - Rated Current: 2A
A DC-DC Boost Step up Converter 5-32V to 5V-55V Power Supply Module - Max 2A
I plan to use a 4s or 6s 18650 battery pack
a momentary switch to charge to desired voltage (the converter has an led indicator)
A momentary switch to trigger it
I am guessing I should use a thyristor/smc for the triggering of the capacitor. There is where I get into trouble! I have no clue what to order? I assume it would need to make sure it could handle the peak voltage and current of the set-up but I have no idea how to figure it out.
Any help is greatly appreciated!
TyeRant
TyeRant
