Captain's Log Stardate 4:
Ethernet Port 7 is bad.
Ethernet Port 8 used for internet.
Minidump for ethernet port 7 and it's driver:
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini091407-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is:
SRV*c:\Tools\WinDbg\WebSymbols*
http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2003 Kernel Version 3790 (Service Pack 2) MP (2 procs) Free
x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 3790.srv03_sp2_rtm.070216-1710
Kernel base = 0xfffff800`01000000 PsLoadedModuleList = 0xfffff800`011d5100
Debug session time: Fri Sep 14 22:56:43.453 2007 (GMT+2)
System Uptime: 0 days 0:36:37.375
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis
Use !analyze -v to get detailed debugging information.
BugCheck D1, {30, 2, 0, fffffadfc7db731d}
Unable to load image \SystemRoot\system32\DRIVERS\yk51x64.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for yk51x64.sys
*** ERROR: Module load completed but symbols could not be loaded for
yk51x64.sys
Probably caused by : yk51x64.sys ( yk51x64+331d )
Followup: MachineOwner
0: kd> !analyze -v
* Bugcheck Analysis
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at
an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000030, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffffadfc7db731d, address which referenced memory
Debugging Details:
READ_ADDRESS: 0000000000000030
CURRENT_IRQL: 2
FAULTING_IP:
yk51x64+331d
fffffadf`c7db731d ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffffadfc904e820 -- (.trap fffffadfc904e820)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed.
rax=0000000000000000 rbx=0000000000000004 rcx=0000000000000000
rdx=fffffadfce7294b8 rsi=0000000000000000 rdi=0000000000000000
rip=fffffadfc7db731d rsp=fffffadfc904e9b0 rbp=0000000000000000
r8=fffffadfce729ab8 r9=0000000080000000 r10=0000000080000000
r11=000000000000280c r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
yk51x64+0x331d:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000102e674 to fffff8000102e950
STACK_TEXT:
fffffadf`c904e698 fffff800`0102e674 : 00000000`0000000a 00000000`00000030
00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffadf`c904e6a0 fffff800`0102d607 : 00000000`00000212 fffff800`0102599b
fffffadf`c904ea00 fffffadf`ce729ab8 : nt!KiBugCheckDispatch+0x74
fffffadf`c904e820 fffffadf`c7db731d : fffffadf`80000000 00000000`00000000
fffffadf`00000200 00000000`00000003 : nt!KiPageFault+0x207
fffffadf`c904e9b0 fffffadf`80000000 : 00000000`00000000 fffffadf`00000200
00000000`00000003 fffffadf`00000001 : yk51x64+0x331d
fffffadf`c904e9b8 00000000`00000000 : fffffadf`00000200 00000000`00000003
fffffadf`00000001 fffffadf`c7db9e32 : 0xfffffadf`80000000
fffffadf`c904e9c0 fffffadf`00000200 : 00000000`00000003 fffffadf`00000001
fffffadf`c7db9e32 00000000`00000000 : 0x0
fffffadf`c904e9c8 00000000`00000003 : fffffadf`00000001 fffffadf`c7db9e32
00000000`00000000 00000000`00000000 : 0xfffffadf`00000200
fffffadf`c904e9d0 fffffadf`00000001 : fffffadf`c7db9e32 00000000`00000000
00000000`00000000 00000000`00000000 : 0x3
fffffadf`c904e9d8 fffffadf`c7db9e32 : 00000000`00000000 00000000`00000000
00000000`00000000 fffffadf`c7db4000 : 0xfffffadf`00000001
fffffadf`c904e9e0 00000000`00000000 : 00000000`00000000 00000000`00000000
fffffadf`c7db4000 fffffadf`ce729008 : yk51x64+0x5e32
fffffadf`c904e9e8 00000000`00000000 : 00000000`00000000 fffffadf`c7db4000
fffffadf`ce729008 fffffadf`c7dba749 : 0x0
fffffadf`c904e9f0 00000000`00000000 : fffffadf`c7db4000 fffffadf`ce729008
fffffadf`c7dba749 00000000`00000000 : 0x0
fffffadf`c904e9f8 fffffadf`c7db4000 : fffffadf`ce729008 fffffadf`c7dba749
00000000`00000000 00000000`00000001 : 0x0
fffffadf`c904ea00 fffffadf`ce729008 : fffffadf`c7dba749 00000000`00000000
00000000`00000001 00000000`ffffffff : yk51x64
fffffadf`c904ea08 fffffadf`c7dba749 : 00000000`00000000 00000000`00000001
00000000`ffffffff fffffadf`ce729008 : 0xfffffadf`ce729008
fffffadf`c904ea10 00000000`00000000 : 00000000`00000001 00000000`ffffffff
fffffadf`ce729008 fffffadf`ce9cc228 : yk51x64+0x6749
fffffadf`c904ea18 00000000`00000001 : 00000000`ffffffff fffffadf`ce729008
fffffadf`ce9cc228 fffffadf`ce729008 : 0x0
fffffadf`c904ea20 00000000`ffffffff : fffffadf`ce729008 fffffadf`ce9cc228
fffffadf`ce729008 00000000`00000000 : 0x1
fffffadf`c904ea28 fffffadf`ce729008 : fffffadf`ce9cc228 fffffadf`ce729008
00000000`00000000 fffffadf`ce72cef0 : 0xffffffff
fffffadf`c904ea30 fffffadf`ce9cc228 : fffffadf`ce729008 00000000`00000000
fffffadf`ce72cef0 fffffadf`ce72cd40 : 0xfffffadf`ce729008
fffffadf`c904ea38 fffffadf`ce729008 : 00000000`00000000 fffffadf`ce72cef0
fffffadf`ce72cd40 fffffadf`c7dd533a : 0xfffffadf`ce9cc228
fffffadf`c904ea40 00000000`00000000 : fffffadf`ce72cef0 fffffadf`ce72cd40
fffffadf`c7dd533a 00000000`00000000 : 0xfffffadf`ce729008
fffffadf`c904ea48 fffffadf`ce72cef0 : fffffadf`ce72cd40 fffffadf`c7dd533a
00000000`00000000 fffffadf`cecfd100 : 0x0
fffffadf`c904ea50 fffffadf`ce72cd40 : fffffadf`c7dd533a 00000000`00000000
fffffadf`cecfd100 00000000`00020105 : 0xfffffadf`ce72cef0
fffffadf`c904ea58 fffffadf`c7dd533a : 00000000`00000000 fffffadf`cecfd100
00000000`00020105 ffffffff`00000000 : 0xfffffadf`ce72cd40
fffffadf`c904ea60 00000000`00000000 : fffffadf`cecfd100 00000000`00020105
ffffffff`00000000 fffffadf`ce9cc228 : yk51x64+0x2133a
fffffadf`c904ea68 fffffadf`cecfd100 : 00000000`00020105 ffffffff`00000000
fffffadf`ce9cc228 00000000`00000002 : 0x0
fffffadf`c904ea70 00000000`00020105 : ffffffff`00000000 fffffadf`ce9cc228
00000000`00000002 fffffadf`ce72a767 : 0xfffffadf`cecfd100
fffffadf`c904ea78 ffffffff`00000000 : fffffadf`ce9cc228 00000000`00000002
fffffadf`ce72a767 fffffadf`cecfd100 : 0x20105
fffffadf`c904ea80 fffffadf`ce9cc228 : 00000000`00000002 fffffadf`ce72a767
fffffadf`cecfd100 00000000`00020105 : 0xffffffff`00000000
fffffadf`c904ea88 00000000`00000002 : fffffadf`ce72a767 fffffadf`cecfd100
00000000`00020105 fffffadf`c7dbb02d : 0xfffffadf`ce9cc228
fffffadf`c904ea90 fffffadf`ce72a767 : fffffadf`cecfd100 00000000`00020105
fffffadf`c7dbb02d 00000000`00000001 : 0x2
fffffadf`c904ea98 fffffadf`cecfd100 : 00000000`00020105 fffffadf`c7dbb02d
00000000`00000001 00000000`00000000 : 0xfffffadf`ce72a767
fffffadf`c904eaa0 00000000`00020105 : fffffadf`c7dbb02d 00000000`00000001
00000000`00000000 fffffadf`ce72a767 : 0xfffffadf`cecfd100
fffffadf`c904eaa8 fffffadf`c7dbb02d : 00000000`00000001 00000000`00000000
fffffadf`ce72a767 fffffadf`ce729008 : 0x20105
fffffadf`c904eab0 00000000`00000001 : 00000000`00000000 fffffadf`ce72a767
fffffadf`ce729008 00000000`00000004 : yk51x64+0x702d
fffffadf`c904eab8 00000000`00000000 : fffffadf`ce72a767 fffffadf`ce729008
00000000`00000004 fffffadf`cecfd0fc : 0x1
fffffadf`c904eac0 fffffadf`ce72a767 : fffffadf`ce729008 00000000`00000004
fffffadf`cecfd0fc fffffadf`cecfd100 : 0x0
fffffadf`c904eac8 fffffadf`ce729008 : 00000000`00000004 fffffadf`cecfd0fc
fffffadf`cecfd100 00000000`00000000 : 0xfffffadf`ce72a767
fffffadf`c904ead0 00000000`00000004 : fffffadf`cecfd0fc fffffadf`cecfd100
00000000`00000000 00000000`00000001 : 0xfffffadf`ce729008
fffffadf`c904ead8 fffffadf`cecfd0fc : fffffadf`cecfd100 00000000`00000000
00000000`00000001 00000000`00000001 : 0x4
fffffadf`c904eae0 fffffadf`cecfd100 : 00000000`00000000 00000000`00000001
00000000`00000001 00000000`00000000 : 0xfffffadf`cecfd0fc
fffffadf`c904eae8 00000000`00000000 : 00000000`00000001 00000000`00000001
00000000`00000000 fffffadf`cecfd0fc : 0xfffffadf`cecfd100
fffffadf`c904eaf0 00000000`00000001 : 00000000`00000001 00000000`00000000
fffffadf`cecfd0fc fffffadf`cecfd0fc : 0x0
fffffadf`c904eaf8 00000000`00000001 : 00000000`00000000 fffffadf`cecfd0fc
fffffadf`cecfd0fc 00000000`00000004 : 0x1
fffffadf`c904eb00 00000000`00000000 : fffffadf`cecfd0fc fffffadf`cecfd0fc
00000000`00000004 fffffadf`c907fd08 : 0x1
fffffadf`c904eb08 fffffadf`cecfd0fc : fffffadf`cecfd0fc 00000000`00000004
fffffadf`c907fd08 fffffadf`c7dbee4e : 0x0
fffffadf`c904eb10 fffffadf`cecfd0fc : 00000000`00000004 fffffadf`c907fd08
fffffadf`c7dbee4e fffffadf`ce729008 : 0xfffffadf`cecfd0fc
fffffadf`c904eb18 00000000`00000004 : fffffadf`c907fd08 fffffadf`c7dbee4e
fffffadf`ce729008 00000000`00000000 : 0xfffffadf`cecfd0fc
fffffadf`c904eb20 fffffadf`c907fd08 : fffffadf`c7dbee4e fffffadf`ce729008
00000000`00000000 00000000`00000000 : 0x4
fffffadf`c904eb28 fffffadf`c7dbee4e : fffffadf`ce729008 00000000`00000000
00000000`00000000 fffffadf`ce729008 : 0xfffffadf`c907fd08
fffffadf`c904eb30 fffffadf`ce729008 : 00000000`00000000 00000000`00000000
fffffadf`ce729008 00000000`00000004 : yk51x64+0xae4e
fffffadf`c904eb38 00000000`00000000 : 00000000`00000000 fffffadf`ce729008
00000000`00000004 fffffadf`cecfd0fc : 0xfffffadf`ce729008
fffffadf`c904eb40 00000000`00000000 : fffffadf`ce729008 00000000`00000004
fffffadf`c904eb48 fffffadf`ce729008 : 00000000`00000004 fffffadf`cecfd0fc
fffffadf`cecfd100 fffffadf`c904ebd0 : 0x0
fffffadf`c904eb50 00000000`00000004 : fffffadf`cecfd0fc fffffadf`cecfd100
fffffadf`c904ebd0 00000000`00000000 : 0xfffffadf`ce729008
fffffadf`c904eb58 fffffadf`cecfd0fc : fffffadf`cecfd100 fffffadf`c904ebd0
00000000`00000000 fffffadf`c820a000 : 0x4
fffffadf`c904eb60 fffffadf`cecfd100 : fffffadf`c904ebd0 00000000`00000000
fffffadf`c820a000 fffffadf`c8229270 : 0xfffffadf`cecfd0fc
fffffadf`c904eb68 fffffadf`c904ebd0 : 00000000`00000000 fffffadf`c820a000
fffffadf`c8229270 fffffadf`cecfd0c0 : 0xfffffadf`cecfd100
fffffadf`c904eb70 00000000`00000000 : fffffadf`c820a000 fffffadf`c8229270
fffffadf`cecfd0c0 00000000`00000001 : 0xfffffadf`c904ebd0
fffffadf`c904eb78 fffffadf`c820a000 : fffffadf`c8229270 fffffadf`cecfd0c0
00000000`00000001 00000000`00000000 : 0x0
fffffadf`c904eb80 fffffadf`c8229270 : fffffadf`cecfd0c0 00000000`00000001
00000000`00000000 fffffadf`ce9cc228 : NDIS!ndisReadRegParameters <PERF>
(NDIS+0x0)
fffffadf`c904eb88 fffffadf`cecfd0c0 : 00000000`00000001 00000000`00000000
fffffadf`ce9cc228 fffffadf`c824b809 : NDIS!ndisMSetInfoHandlers
fffffadf`c904eb90 00000000`00000001 : 00000000`00000000 fffffadf`ce9cc228
fffffadf`c824b809 fffffadf`cb78c138 : 0xfffffadf`cecfd0c0
fffffadf`c904eb98 00000000`00000000 : fffffadf`ce9cc228 fffffadf`c824b809
fffffadf`cb78c138 fffffadf`00000103 : 0x1
fffffadf`c904eba0 fffffadf`ce9cc228 : fffffadf`c824b809 fffffadf`cb78c138
fffffadf`00000103 fffffadf`ce17d4d8 : 0x0
fffffadf`c904eba8 fffffadf`c824b809 : fffffadf`cb78c138 fffffadf`00000103
fffffadf`ce17d4d8 fffffadf`c76a4710 : 0xfffffadf`ce9cc228
fffffadf`c904ebb0 fffffadf`c824b373 : fffffadf`cecfd0c0 00000000`00000000
fffffadf`ce9cc228 fffffadf`cecfd0c0 : NDIS!ndisMDispatchRequest+0x1c2
fffffadf`c904ebf0 fffffadf`c824b5c4 : fffffadf`cb78c138 00000000`00000000
00000000`00000000 fffffadf`ce9cc228 : NDIS!ndisMQueryInformation+0x54e
fffffadf`c904ec20 fffffadf`c82541bf : fffffadf`ce9cc228 fffffadf`ce9cc228
fffffadf`cecfd0c0 fffffadf`cecfd0c0 : NDIS!ndisMDoRequests+0x53b
fffffadf`c904ec80 fffffadf`c824b6ef : fffffadf`ce553660 fffffadf`ce9cc228
fffffadf`cecfd0c0 fffffadf`cbd4b8c0 : NDIS!ndisMRequest+0xdb
fffffadf`c904ecc0 fffff800`0103768a : fffffadf`cbd4b8d0 fffffadf`c824b620
fffffadf`cecd67a0 fffff800`011ce980 : NDIS!ndisMRundownRequests+0x44
fffffadf`c904ed00 fffff800`0124b972 : fffffadf`cecd67a0 00000000`00000080
fffffadf`cecd67a0 fffffadf`c8c83680 : nt!ExpWorkerThread+0x13b
fffffadf`c904ed70 fffff800`010202d6 : fffffadf`c8c7b180 fffffadf`cecd67a0
fffffadf`c8c83680 fffff800`011b5dc0 : nt!PspSystemThreadStartup+0x3e
fffffadf`c904edd0 00000000`00000000 : 00000000`00000000 00000000`00000000
00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
yk51x64+331d
SYMBOL_STACK_INDEX: 3
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: yk51x64
IMAGE_NAME: yk51x64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 42709a67
SYMBOL_NAME: yk51x64+331d
FAILURE_BUCKET_ID: X64_0xD1_yk51x64+331d
Link to minidump:
http://members.home.nl/hbthouppermans/WinXPx64ProMinidumps/
Minidump filename is: Mini091407-01.dmp
(Created and Uploaded 14 september 2007)
Marvel miniport driver version is: 8.27
I shall remove this driver and go to the windows update site, download the
newest driver from microsoft,
Then I shall repeat the test.
If this does not fix the bad port I might go to the website located at:
http://www.marvell.com/contact/cust_support.do
I don't need customer support, I need a good working driver.
Maybe that website has a good driver somewhere.
Final possibility:
Kasparov's Anti Virus 6 fucked up the tcp-ip stack.
Though it seems this driver just bad.
UDP Speed Test has proven it's value for the second time in only a few days
Very nice !
Soon a new version will be available at (with many improvements, mostly gui,
some speed too):
http://www.myjavaserver.com/~skybuck
End of log.
Bye,
Skybuck.
