arif1996
Hi...
I am using a standerd buck boost configuration. A inductor, diode(60EPF)
capacitor and a MOSFET switch(IXFN80N50). The buck boost is designed s
that it will handle 1.8KW power. All the rating of the component value ha
come through calculations and ensures that the converter will operate i
continuous conduction mode.
During designing, I considered that the variation of the input voltag
should be between 50-250 volt and output voltage should stay at 120 v. Bu
I don’t have any control on the output and I also don’t need that for m
purpose. I will be trying to track the maximum power of a wind turbine
All the algorithm will be done to a PIC 18F452 and it will generate th
required PWM signal and thus switch the buck boost. Now PIC can only giv
us 0-5 volt. So,I used a driver stage(with TC 4420) to drive the MOSFEE
which will give me 0-15 volt proportional to PIC signal. Driver and PI
has isolated ground with an optocoupler. Siganl from the driver i
connected to the gate of MOSFET and ground of the driver connected to th
source i.e. high side driving configuration.
The problem is :
Lets say, switching frequency is 100KHz and duty cycle is 50% from the PI
, so the driver stage ouput is 50% duty cycle with 0-15 volt voltage leve
and frequency is 100KHz to drive the MOSFET. Its ok. I have seen it.Now i
I increase the input voltage level, say…10…20…30…gate signal ok…switchin
the MOSFET…getting output voltage.
But if I increase further…say…40…50…60…gate signal distorts i.e. i
doesn’t show me 100Khz and so as the 50% duty cycle…gate signal jus
vanish after a certain input voltage...getting output voltage but tha
doesn’t make much sense.
I am stacked on this point and trying to search some literature but ther
is not much information about any practical solution. Waiting for any kin
of suggestion.
Today i have bought IR2117 and IR2110 to use for a driver circuit. The
have isolated ground and are useful for both high and low side driving.
have calculated my input driver circuit current to charge up the MOSFET G
cap and i have found that if a driver circuit can give me 6 amps then i
will be ok. But in the data sheet of IR 2117 i didnt see any informatio
about how much current it can give? It says Io+ 200/400mas..i am confuse
in this point too.
Will it be able to drive such high power level(around 2KW) MOSFET? I hav
seen that they are suitable but i need to be sure from someone or need t
understand what does it mean?
A lot of questions but hope some former will guide me through the righ
way. I am stacked on this issue for along time.
Arif
The problem is :
of suggestion.
in this point too.
Arif
