I need a schematic for a small electrical project. I want to hook up two computer case cooling fans to one standard 120v plug. That’s two fans into one standard 120v outlet.
The fan model is CoolerMaster 120-SI2, which has a 3-pin molex wiring harness. Red wire: 12V. Black wire: 0V (ground). Yellow wire: RPM sensor. Here are the fan’s specs:
Voltage: 12VDC.
Current (Ampere): 0.15 A±10%.
Input (Watt): 1.80W±10%.
Can anyone give me a safe way to wire this up? Without building a new wiring, I would need to buy a 3-pin to 4-pin adapter and an AC power supply for each fan. This is unacceptable because of space and budget limitations. Can anyone help? Thanks!
Voltage: 12VDC.
