lemonjuice
Tim Hubberstey wrote...
I posted a note concerning startup. This type of bootstrap circuit
start up fine if the opamp's output has more BJT saturation voltage
than the input's offset (divided by the feedback-resistor ratio), so
when the power is applied, the + input sees a bit more voltage than
the - input and drives the output further toward the turned-on state.
There are two problematic issues. First, the feedback resistors to
common tend to reduce the BJT saturation voltage. Using high-value
resistors helps; e.g., here they draw a current of 30nA for say 30mV
of output-transistor saturation. We note that 30nA is probably much
less than the base-drive current for the PNP output transistor.
Second, when the output is only modestly-higher than the reference,
the "offset voltage divided by the feedback-resistor ratio" parameter
becomes painful. Here we would divide our estimated 30mV by 12.5 to
get a 2.5mV max offset-voltage spec, which might be hard to meet.
Assuming the anode of the zener and the 1Meg output resistor are
earthed V(+) = V(-) at the opamp inputs would be = Vee. If we had a
opamp configuration like a 741 the input transistors would be cut off
as would the darlington stages. That would force the opamp output into
a positive direction . With other Opamps any other simple solution
would do.
