John S
lt-spice crashed before I coiuld save it.
when I had it start with the switch open it'd put 15GV on the
capacitor
That's probably because your input is a current source and you waited
too long to close the switch.
capacitor
Oops, I probably mixed you up with someone else. I thought it was stage
electronics for rock bands and stuff.
That was the last job. ;-) I've done a few career changes in the
last 10 years. Before that, one employer, oneish (perhaps two)
markets, but very different jobs every five to eight years.
You have a very small view of the automotive market. That is for
sure.
ECUs have changed more than a little in 30 years. They will change
drastically, again, over the next ten. ...
... Hell, you'd have a hard time
showing up for work with your pants on, after being a consultant that
long. ;-)
Thanks, George. It believe this is a standard buck switcher without the
output filter capacitor.
Alas, the compliance current is around 50mA with a compliance voltage as
high as 1kV, which is destructive. A 'straight' shunt regulator either
shorts out the incoming 50 mA or let's it pass thru, but in this case I
sometimes need 800mA at a small 5Vdc. So, need some 'multiplication' of
the current - a capacitor. There is sufficient power if the system
operates with the compliance at around 80V at 50mA just have to somehow
convert that to 5Vdc at 800mA. But, in this case it will be super
necessary to monitor compliance voltage so it won't EVER go above 100V
in order to NOT kill parts. In this supply that protection circuit, or
'voltage limit', is the corollary of the standard 'current limit' in a
voltage supply!
So far it appears a variation of George Herold's approach may get me
there. the current charges a cap, which then supplies large amount of
power. Aain, corollary, using cap instead of inductor for the energy
storage/conversion.
Hi John, Here's the current to current buck that I drew... from upstream
https://www.dropbox.com/s/h2a8dyz0vzoovev/DSCF0031.JPG
I guess I could try simulating these, if I ever get 'free' time.
George H.
Hi, Robert -
The thread has grown more to than I can re-read to capture all your
requirements. However, here are my thoughts...
Max allowed input voltage: 100V
Input current capability: 50mA
Output voltage required: 5V
Output current required: .8A
....snip...loss of extra thoughts due to using AIOE that won't let me
quote more than ?? number of lines...
-If it can be open or very high, then you need to provide another device
at the input, perhaps a depletion FET capabale of about 100mA at a few
hundred volts to stop things when the duty cycle is commanded to be at
100% or a bit less.
Just some thoughts. I apologize if I have stepped on any toes.
Yes, thank you, George. I saw it. But your image and your ASCII drawing
above do not agree. Your ASCII drawing is a standard buck without an
output filter capacitor. I agree with your ASCII (with, possibly, the
requirement for an output filter capacitor) for a scheme which could work.
I'm having a lot of fun in my smps course. Maybe I'll have to build one
someday and 'really' learn something :^)
I've often thought there might be a niche vacation market for geeks.
Instead of going to the the ocean or mountains, you go to 'school' and
intensely learn a new subject.
When I was at the FEL in Vanderbilt I went to "accelerator school"
http://uspas.fnal.gov/programs/1998/Stanford/courses/magneticsystems.shtml
(I think that might be it.)
It was great! Each night we'd sit around with a few beers and do the
homework together.
George H.
Phil said:[...]
As a consultant I get to wear shorts all summer long. When a web
conference with bigshots is coming up I have a "dress shirt on duty"
hanging in the lab closet
I just change into a new golf shirt. The good news about being a solo
consultant is that it's up to you. The bad news is also that it's up to
you.
Not always. For example, on Friday I had to wear a more formal attire
including a tie. The CEO that picked me up from the airport down south
also did. Well, I could have just not worn a tie but in that situation
is was customary and probably expected.
5-8 years would be a bit much for me.
I see it from two view points. One is the actual product and that often
doesn't look very good, both from a quality point of view and sometimes
also from an engineering point of view (flickering LED backlights
anyone?). Then from a people perspective and here talking to folks who
actually work in that field helps. Pretty much all of them reported
extreme pressure to keep NRE and R&D schedules down, which explains a
lot of the quality issues. To the point I wouldn't want to work there.
As a consultant maybe but niot if they'd demansd unrealistic timelines
like they often do from their employees.
There are automotive electronics that work quite well, mostly in
Japanese cars. In the end it boils down to the reliability ratings of
the various entities in the know.
Sure, incremental change. Same in medical ultrasound which is my home
turf. But ... after we built a flagship product in the late 80's and the
satellite R&D location was closed afterwards I wasn't too unhappy that I
could jump into consulting for the first time, and do something else.
Sure, when you're at their site. I wear a jacket when I'm doing video
Skype interviews with clients, too--especially lawyers. (It's
convenient that my drawing table is just across the room from a wall
full of books.)
Cheers
Phil Hobbs
A table? A wall of books? I didn't know you were into 'antiques'.
In my last job I was the only one who wore long pants from April to
October. Everyone else in Engineering wore T-shirts year 'round. I
can't do that. I wear long-sleeved shirts (Oxfords, preferred) even
for mowing the lawn.
Cost is everything but it's still no excuse for designing junk. ...
... In
that regard, it's not a lot different than what you've described that
you do.
Things change. A lot!
You can see the aforementioned table and bookshelf in my virtual lab
tour, http://electrooptical.net/www/EOILab/EOILab.html .
It looks pretty much like that, except that I have a bunch more
furniture (two big lab benches and a table in the whiteboard/reception
area, plus some more in the admin/layout space). I also have way more
equipment. I've been meaning to replace the pictures, but the lab
hasn't been that clean since 2011.
Cheers
Phil Hobbs
RobertMacy said:I have a voltmeter.
You've got the gist of the problem. I made up some of the numbers and
didn't notice they didn't quite correlate. But you see the premise for
the problem.
To maintain some semblance of efficiency, I can't simply 'shunt' unused
power off.
Grin.. sure... the ascii is a current boost and the first dropbox
scribble is a current buck. I'm not sure what you mean about the
ascii drawing... It's being fed from a current source.. so how can
it be a 'standard buck'. (The output is also a (DC) current.. so I
can't really put a capacitor there.)
You should also note that the ascii has a current source feeding
right into a capacitor! (But that really does seem analogous to the
voltage boost where the voltage source feeds an inductor... both
will 'rail out' if not part of the switching scheme.)
John said:So, you cannot provide a short circuit for the current source? You are
in deep trouble.
